Network address weirdness
I'm seeing some weird behavior with my new BBAI setup, perhaps someone can tell me what I'm doing wrong. I have six other KiwiSDRs here, and have never run into this problem with them.
I configured it for a static IP address of 192.168.0.76 a few days ago. All was fine at that address. This morning I noticed that last night around 9 PM local time, this KiwiSDR vanished from my KiwiSDR Monitor status display. I checked the cylon LED display and it was showing 192.168.0.198. Sure enough, I could log into it there. Here's what the Network admin tab shows. You can see the IP address I set in the field, but down at the bottom it displays: Private IP address (inside your firewall/router): 192.168.0.198
A few times this morning I could change the IP address and reboot, connect at that address, then after a few minutes it would revert back to 192.168.0.198. Now I can't even do that, it immediately switches back.
Is there another network configuration inside the BBAI that needs to be changed?
Update, ifconfig output does imply it is still getting a dynamic address:
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
    inet 192.168.0.198 netmask 255.255.255.0 broadcast 192.168.0.255
    inet6 fe80::5251:a9ff:fe98:7dbc prefixlen 64 scopeid 0x20<link>
    ether 50:51:a9:98:7d:bc txqueuelen 1000 (Ethernet)
    RX packets 13563 bytes 1858310 (1.7 MiB)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 8950 bytes 1645449 (1.5 MiB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    device interrupt 127
