Feature Request
Having a number of KiwiSDR, managing them can be a challenge, configuration wise. I wonder if it would be possible to add something on one of the admin tabs to load configuration files? With that all of my kiwisdr's could have the config files for each other and if I have to switch, I can just load the desired config.
See second section of admin "config" tab. All configuration files can be cloned from another Kiwi or just the dx (aka label, tags) file.
Maybe you had a variation of this feature in mind?
yes.... a way to keep the file collection on each kiwi, preserving each. The cloning overwrites AFAIK.
Does the clone feature also not require "root"? not enabled by default on the AI.
In the case of the BBAI:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#i_take_full_responsibility_for_knowing_my_beagle_is_now_insecure
I would like to see a variation where it is possible to clone a complete config *except* the IP address. (Is there even a situation where cloning the complete config *including* the IP address is wanted?) BTW I use static IPs.
yes, my idea would not have IP# either.
