Real Time SWBC Shortwave Broadcast Station Schedule
This is a work in progress, but perhaps useful for some. It's an online real time SWBC schedule, driven by the EIBI schedule database.
You can enter in various parameters (country, target, language, bands, etc.), and see a list of stations currently on the air. More useful for KiwiSDR users, you can also enter a list of KiwiSDRs (saved via cookies for your next visit) and links to those KiwiSDRs will appear next to each entry in the SWBC schedules results. So you can just click on a link to be taken to that KiwiSDR, and tuned in to the broadcast.
In addition to SWBC transmissions there are also some utility transmissions and other broadcasts. Unfortunately the EIBI database does not have mode (AM, USB, etc) information, so the schedule makes some guesses based on the frequency, which is occasionally wrong for out of band SWBC transmissions.
https://www.hfunderground.com/on_the_air/update.php
Could someone please explain to me how I can call up this list of stations that are currently transmitting?
I am using a Macbook Pro M1 and the function ctrl, alt, shift does not work.
When I right click I see a function with a link to SWBC Database Lookup but then I get the message server not found?
Thanks in advance for your help.
Theo
I use an M1 Pro and it works for me.
But there was an issue with Firefox a little while back where it got an error with the SWBC site which does not support HTTPS. Other browsers were okay. But the latest Firefox (133.0) doesn't seem to have this problem anymore.
@jks , Thank you for the reply. Indeed I am using Firefox 133.0 and still having this 'problem'.
Did try it with Safari and the same message server not found.
Knowing that it works on your side and did not found any other users with this 'problem' most likely it has to do with my network.
73 all the best.
@theot Perhaps it is this problem? (It's redirecting to an invalid address)
https://forum.kiwisdr.com/index.php?p=/discussion/3452/swbc-lookup-adding-both-http-and-https-to-the-url#latest
Which should be fixed in the next release.
How often is the Eibi database uploaded?
It's not automatic. I have to do it by hand. It's published every six months at eibispace.de
I see A25 is out, so I'll try and get that in the next Kiwi release.
I made this a while ago, also driven by EiBi...
You can filter by typing into the box. Click time to load that time. Click column headers to sort. This is also not all that refined, but it works.
Would a cron job handle this to check for updated lists? Perhaps staggered so not all Kiwis hammer the site at once.
There's absolutely no need for individual Kiwi's to be downloading from there when it needs to be compiled into a compact binary form as part of a release. The list is huge and fetching it off the filesystem of the Kiwi would break the Kiwi realtime restrictions (i.e. audio failures).
I improved my own Makefile so there's less manual work to update the list.
