Bad Password Error
What causes a bad password error? I'm trying to run a simple record command that I've run countless times before, but I'm getting a KiwiBadPasswordError.
Update: To help me debug, I added a print statement to print out the command before it's executed, and when I did this it ran without failure. This is the only thing I changed in between a failed and successful run. No idea why I got the error, as the server host doesn't require a password.
File "C:\kiwirun\Kiwi\kiwi\client.py", line 298, in _process_msg_param
raise KiwiBadPasswordError('%s: bad password' % self._options.server_host)
kiwi.client.KiwiBadPasswordError: : bad password
I only run linux so not sure about your Win install
What is the exact command?
I tested kiwirecorder.py and it does work. What I had in mind was to be able to use a time limit excemption password in kiwirecorder.py. But I see that this possibility was added by John in January this year (
--tlimit-pw
)python3 kiwirecorder.py -k 30 -s bonaire.twrmon.net -p 8073 -f 800 -m am --tlimit 60 -d 'RESULTS' --hp-cutoff=5000 --s-meter=0 --sdt-sec=60 --ts --snd --fn=filename
And no, kiwi\client.py is correct @WA2ZKD
