KiwiSDR not responding
My KiwiSDR isn't responding to IP calls (http or ping). After restarting the device, and even restoring the firmware, it appears to be getting an IP address according to my router. The blue light on the far left of the device is flashing twice in quick succession.
Anyone have any ideas?
Thanks.
Thanks.
The double-flash of the LED closest to the PCB edge means Linux is running, but the Kiwi server didn't start. Although note: it take one minute after a restart, and the double-flashing, for the Kiwi server to get going and begin showing it's own LED pattern as described on kiwisdr.com
It's possible the file system has become damaged by a sudden power down at a bad time (e.g. in the middle of a filesystem write) and now it's unable to start the server. We've seen this before. Although a re-flash from the backup sd card should cure this problem.
It would really help if port 22 (ssh) could be opened on your router and mapped to the Kiwi so we could login and check it. If you can manage this please email your public ip address and the Kiwi serial number (written on top of Kiwi PCB in white silkscreen box) to support@kiwisdr.com
I'll follow up with you on the support email address. Thank you! 73.
