GPS is always Paused
I am setting up a new KiwiSDR. The GPS never acquires any satellites, apparently because acq is "paused" and never "yes." This true for zero users and any setting/check box on the GPS tab that I can find. It survives any reset or power down. If I run a receiver, it shows "v1.356, 4 SDR ch, 12 GPS ch, GPS acq pause, track 0, good 0, fixes 0." Somehow this must be set in a config file in the BBG? I can't see where others have this problem. Can someone help me?? Thanks, Bob
Connect to the admin page. Select the "console tab". Click the "connect" button.
On the "enter shell command" field at the bottom of the page type these commands: In the output that appears in the box above do you see, in red, "enable_gps"? Is it followed by "true" or "false"?
Thanks.
Also, is your Kiwi available from the Internet? If so please email the ip address or URL to support@kiwisdr.com and I'll look at it.
On the GPS tab try these settings then see what it is doing.
It might be that it was doing the full update so paused but the page has not properly refreshed.
As I said long shot but good to refresh the admin page first whenever something does not seem right.
OK, Running the BBG Console:
root@kiwisdr:~/kiwi.config# gr enable_gps admin.json
{"user_password":"","user_auto_login":true,"admin_password":"..removed..","admin_auto_login":true,"port":8073,"enable_gps":false,"update_check":true,"update_inst
all":true,"sdr_hu_register":false,"api_key":"replaced with API key from sdr.hu/register","port_ext":8073,"firmware_sel":0,"tlimit_exempt_pwd":"","server_enabled
":true,"auto_add_nat":true,"duc_enable":false,"duc_user":"","duc_pass":"","duc_host":"","duc_update":3,"daily_restart":false,"update_restart":0,"ip_address.dns1
":"8.8.8.8","ip_address.dns2":"8.8.4.4","url_redirect":"","ip_blacklist":"47.88.219.24/24","no_dup_ip":false,"my_kiwi":true,"options":0,"GPS_tstamp":true,"use_k
alman_position_solver":true,"rssi_azel_iq":0,"always_acq_gps":true,"include_alert_gps":false,"include_E1B":true,"survey":180,"E1B_offset":4,"acq_Navstar":true,"
acq_QZSS":true,"QZSS_prio":false,"acq_Galileo":true,"plot_E1B":true,"rev_user":"","rev_host":"","ip_address":{"use_static":false,"ip":"192.168.0.201","netmask":
"255.255.255.0","gateway":"","dns1":"8.8.8.8","dns2":"8.8.4.4"},"onetime_password_check":true}
The interesting variable would seem to be "enable_gps":false
It is not available yet on the internet as I am still learning router-speak. Soon, I hope.
Bob
Then immediately go to the "control" tab and click "KiwiSDR server restart" and "Confirm" without doing anything else in-between.
"enable_gps" is an old config setting that was superseded by the three GPS system settings (Navstar/QZSS/Galileo). There is code to force it "true" but somehow that has failed us here.
Success, "gr enable_gps admin.json" produces ..."enable_gps":true, ...
The GPS tab no longer shows acq:paused
AND We are tracking satellites:GPS: acquire yes, track 5, good 2, fixes 0
Given time and maybe better antenna position (it is inside now) all will work.
Thanks much. I don't know how it got there, but its FIXED. Bob
