No SDR.hu listing [ISP problem, temp fix by using the proxy service]
Hi all,
I've seen an older discussion about the same, but that was in 2017 and was fixed....
I was previously successfully listed on SDR.hu. When I came back from my last trip I switched on the kiwi and it was not showing anymore.
I checked the kiwi sdr.hu page and I see:
sdr.hu registration status:SUCCESS (update)
Even reboot or select yes (or no first) always comes with SUCCESS, but I dont see a listing...
From the command line with ms i also see a success:
Sep 21 04:36:11 kiwisdr [822]: 00:00:42.252 .... sdr.hu registration: WORKED
Anyone has an idea why the listing is not working anymore?
Cheers,
Rick
Cheers,
Rick
Your Kiwi, assuming it's really rick-kiwi.servebeer.com:8073, is registering fine on kiwisdr.com (and presumably sdr.hu). But there is no response when kiwisdr.com goes to get info from rick-kiwi.servebeer.com:8073/status. So you don't get listed. I also tried the ip address that domain resolved to. Same result, no response. Is port 8073 open? I also can't make a regular user connection.
Ok let me investigate.... I really should get rid of that custom domain and use my regular ...
Ill report back later ...
Cheers,
Rick
So I never expected this to be an issue, but it is ...
Something has changed on my provide side, I just cant figure out what yet ... Packets just dont arrive at my firewall (also for other applications).
Well, i got some work to do figuring out what they did this time
Thanks for pointing out the reason why its not showing ...
Cheer ...
