KIWI audio problem
My KIWI server starts OK
Ports LAN and WAN working
I can access my KIWI remotely.
I have a waterfall display and verified signals.
My problem is that I recover no audio, JUST WHITE NOISE.
What settings did I scrrew up?
  • What OS/Browser, have you muted it (keyboard M) or on the browser tab, what modes?
  • It's a local problem.... routing issue.... I have helped him
  • White noise? How could a routing problem cause white noise? I'd like to know more about this. If packets are getting dropped with the audio in compression mode (the default) that might do it I suppose.
  • He'll have to explain it. I can access his remote unit NP, He can access mine NP. But yet, depending on how he routes (his report), he has the white noise issue.
  • He should try turning off compression and see if things change ("Comp" button on Audio tab of main control panel).
