v1.281: signal generator extension, audio FFT fixes
v1.281  April 12, 2019
    Add URL parameter "peak" to set spectrum peak hold mode (overrides last value saved in cookie)
        e.g. "&peak", or redundantly "&peak=1", but more usefully "&peak=0"
    Audio FFT:
        Allow URL parameter "no_wf" to be used in 4 and 3-channel modes, not just 8-channel mode.
            This is useful e.g. if you want to use the audio FFT to study the frequency response of
            the new de-emphasis filter in 20 kHz mode (3-channel mode) where you would otherwise
            never be given the audio FFT because there is no shortage of waterfall channels.
        Added missing window function to FFT.
        Fixed scale/waterfall click frequency in non-IQ modes.
    Added signal generator extension. When enabled replaces ADC input to audio/waterfall DDCs
        with a tunable RF signal source using the same FPGA DDS IP block used by the DDC mixers.
        WARNING: Be careful about drawing conclusions re Kiwi performance and possible bugs
        when using the sig gen. It reveals spurious responses in the waterfall/spectrum to a greater
        degree than if you just tune around with an antenna connected. But without detailed
        experimentation it can be difficult to know where the limitations are. Remember that the
        Kiwi is a carefully balanced compromise to get 4-channel mode to work (i.e. fit in the FPGA
        and have enough Beagle CPU cycles). So the DDSs, mixers, DDCs and FFTs are not perfect.
        Speaking of compromise, when considering FFTs it's important to understand this:
        https://en.wikipedia.org/wiki/Spectral_leakage
HB9TMCWA2ZKDG8JNJ
    This is an interesting addition.
    Is there any way the signal generator output could be routed to the outside world, for example on one of the GPIO pins, or by means of a hardware hack ?
    edited April 2019
    Sure, but it would just be a square wave that you'd have to clean up or use to sync something. I could send it to one of the P8 GPIO pins.
    I've had this sig gen capability for years but have resisted releasing it (until now) because I just knew it was going to cause trouble for me. But it has some utility now sweeping filters and whatnot (edit: I meant internal to the Kiwi).
    But it's not a terribly clean signal. The SFDR is only about 90 dB. This is because this is the greatest SFDR that can be wrung out of the Xilinx DDS IP block so that it uses only a single "BRAM" (FPGA memory block). BRAMs are the FPGA resource that is in shortest supply. With the addition of the sig gen 100% of the BRAMs are now in use. Every single one (for the rx4/wf4 configuration).
  • Since not only the frequency but the phase of that test signal is known and repeatable, it offers the possibility of building a rather simple vector network analyzer. Either transmission (e.g. S21) or reflection (S11) measurements could be relatively easily performed with only the addition of a simple directional device, or even without that in the case of "1 + gamma" measurement.
    This sort of functionality is almost certainly beyond the charter of an SDR receiver but it is nevertheless a terribly useful piece of test equipment and one that is probably quite under-appreciated. It could go well past scalar, magnitude only measurements of filters (or whatnot).
    The spectral purity of a source like that would certainly be an issue and I'm not sure how one would easily implement a tracking filter or other sine-wave approximation from a square wave but the possibilities are intriguing.
    Maybe you've just let the cat out of the bag John :)
  • edited April 2019
    OK that sounds EXTREMELY promising.
    My thoughts were that it could be used for a few purposes.
    1. Used as a frequency reference to lock external transvertors / convertors to the KiWi. Especially if folks are now getting interested in possibly using the KiWi for VHF/UHF & Microwave bands. For those of us lucky enough to be within the footprint of the new Es'Hail QO-100 geostationary amateur radio satellite transponder, this sort of technique is being used to lock the 25 or 27MHz reference in place of the domestic LNB internal crystal when down converting from 10GHz.
    2. Used as a handy signal generator to test the gain / frequency response of items placed ahead of the KiWi, which would allow alignment of items such as BC notch filters and slope equalisers.
    3. Testing the gain / frequency response of antennas used with the Kiwi. If the output signal is a square wave. it may be possible to set say a frequency of 1MHz (or 100KHz) and use the output as a comb generator instead of having to sweep it.
    4. If the output level into the ADC is known, then if the signal could be applied to an external device,such as a filter or pre-amp, and a calibration correction could be derived and internally generated from the stored results. This would allow automatic S-Meter calibration to be achieved.
    5. Could the generated signal be time stamped with internally GPS derived pulses or 'clicks' so that it could be used to test / calibrate the TDoA when required.
    Misc musings......
    In order to keep P8 clear for possible expansion of GPIO switching, would it be feasible to use any of the 'spare' pins on P9.
    P9 - 11 GPIO mode 7 0_30
    P9 - 23 GPIO mode 7 1_17
    P9 - 26 GPIO mode 7 0_14 (not sure if this one could be used)
    Unlike most other extensions which don't cause problems for multiple users, when the signal generator is in use it prevents all other users from receiving any off-air signals.
    Maybe the Signal Generator controls should be in the admin menu rather than available to users as an extension. This would also allow it to be permanently enabled if it was required to lock a convertor.
    For items 2-4 it would be nice to have two 'peak hold traces' - Yeh, nah :-) so that you could compare 'before' and 'after' results of any changes.
    Now taking cover......
