v1.254 fixes TDoA spurious "no recent GPS timestamps" bug
in TDoA topics
Quite often you can select a TDoA sampling Kiwi which will report sufficient GPS timestamps and then get added to the station list without a problem. But when you go to actually run the TDoA the Kiwi reports "no recent GPS timestamps" at the end of the 30 second sampling period.
The underlying cause of this bug has finally been understood and fixed in v1.254. This behavior can still happen legitimately if the Kiwi is computing a marginal number of GPS solutions. Such as if the number of GPS timestamps when you initially select the Kiwi is substantially less than 30.
