VK6KCH
- VK6KCH
- 56
- 9
Opinions needed: Ham radio digital modes -- what's currently being used?
The latest issue of Amateur Radio (Vol 93) has a great article on FreeDV on HF, by Peter VK3TPM. This has prompted me to do a bit of further digging around, and it really does seem like a great step forward, and so impressive that the codec is open source.
It appears that FreeDV can run on a Raspberry Pi, so I wonder if it's possible to add this as an extension inside KiwiSDR?
I also confirmed that there was a decent level of activity to listen to, such as on 7177 kHz. (Actually, this is potentially confusing... the traffic was below 7177kHz, as though the old analog LSB convention was being used... anyway...). It's easy to find active traffic, by searching for a transmitting station on the QSO reporter at https://qso.freedv.org/
In summary : sure would be cool to have the ability to decode and listen to FreeDV directly inside the KiwiSDR!
Chris
VK6KCH
Register Kiwi SDR online
An update on my "shy" KiwiSDR : in short, it's back up and running!
I didn't add any entries to the blacklist at all, nor make any config changes. I think it was just some strange race condition to do with powering up the entire remote site at the same time after the RFI improvements were made, and the 4G router has a strange pattern of connecting to the cellular network, disconnecting, and then reconnecting shortly thereafter. I wonder if the KiwiSDR registered an outbound connection in that first short window, but didn't realise the session was half broken and then clear it down and start again?
Anyway, the KiwiSDR has been up and running the whole time, just not remotely accessible. I could see that the WSPR and FT-8 receive traffic was being reported due to the autorun sessions, hence how I knew it was up and running ok.
I was hoping that the KiwiSDR could still call home for firmware updates, and I believe this was the case, as it has now updated to v1.809. I believe that the restart associated with the firmware upgrade caused a new session to the proxy system, and voila, it's back up and running and I'm able to access it again! Phew!
In the meantime, I had purchased an Arlec PC191HA from Bunnings, which is part of the Grid Connect family of products, and am planning a trip to the site in the next few days so I can remotely power cycle the unit in the future. However, the firmware upgrade beat me to it! :-)
73, Chris vk6kch
66.666 MHz TCXO for KiwiSDR. Jamming/spoofing GNSS.
Just a random thought; what about using WSPR receive mode, and comparing the signals received at the local station, versus a couple of nearby stations? Wouldn't that achieve pretty tight frequency calibration? (The WSPR signals should be less prone to false detection that ye olde time signal carriers, and you could try at 28MHz to start with).
73, Chris
Hi John and Thierry,
Thanks for your replies. The KiwiSDR is behind a 4G router, so there's a stage of outbound NAT there (with no explicit port forwarding to handle inbound connections), and then on top of that, the 4G router is only assigned a CGNAT IP address, so there's another stage of NAT occurring on the cellular service provider's edge. I had assumed that only outbound TCP sessions would work, and that attempts to initiate inbound traffic (TCP or UDP) wouldn't work, thanks to the NAT barriers (especially the cellular service provider's edge)... hence the beauty of the proxy service! It was all working fine up until recently, so the overall architecture is viable.
I suspect that an outbound TCP session from the KiwiSDR to the proxy server has collapsed and not been reestablished? Or, is it even a UDP "session", rather than TCP? (I'm now wishing that I'd inspected the traffic with wireshark earlier, but I was focused on the RF side of things).
In the short term, I'll just have to hope it fixes itself, but I'll try to get back to the remote site in the next week or two and try rebooting the KiwiSDR whilst keeping the 4G router powered up. (I wonder if the issue was caused by the whole system being power cycled as part of the changes I was making, and a race condition being entered that has messed up the NAT table, especially as the 4G router has a habit of connecting to the cellular network for about a minute, then disconnecting and reconnecting again soon after... did the KiwiSDR establish the outbound NAT during the first short connection window, but it's not honoured during the currently established connection?)
In the longer term, I wonder if there's a way that the KiwiSDR can detect that the connection to the proxy service is a bit of a zombie, and then clear it down and rebuild it, or even force a complete reboot, to try to reestablish service? (If that feature is enabled... don't want to be rebooting any completely standalone installations that are only meant to be used locally!)
Chris
Allow DRM to preempt autorun FT-8 and autorun WSPR [fixed in v1.806]
