RobRich999
Radio Free Citrus 🍊 | KiwiSDR 2 0-30MHz | 148' Loop-on-Ground | Citrus County, FL USA Radio Free Citrus 🍊 | WEB-888 0-30MHz | 30' Inv Delta Loop | Citrus County, FL USA
RobRich999
1
3
  • v1.707
    Cleanup logs older than one day:
    sudo journalctl --vacuum-time=1d
    If desired manually delete old archived logs and rotated logs:
    sudo find /var/log -type f -regex ".*\.gz$" -delete
    sudo find /var/log -type f -regex ".*\.[0-9]$" -delete
    Local Git repo cleanup and compress deltas:
    sudo -i
    cd /root/Beagle_SDR_GPS/
    git clean -ffd
    nice -n 19 git gc --force --prune=all
    The git gc housekeeping takes awhile to run. Use nice to set a low priority if running on an active Kiwi server. You can add --aggressive to git gc if really adventurous, but it could take a very long time to run. YMMV.
    Cleanup local APT cache:
    sudo apt clean
    Usually I end up with around 800MB+ free on my KiwiSDR 2.
    rz3dvpsmgTremolat
