studentkra
- studentkra
- 8,338
- 33
Antenna switch | Kits | Commercially available?
Anyone know what this guy is saying?
Poll: Remove electronic attenuator in future Kiwi-2 builds
I successfully use an external attenuator for KiwiSDR1. The attenuator is assembled on the PE4302 board and ESP8266. Control is via USB connection to KiwiSDR. The attenuator works in a simple automatic mode. At night, a signal attenuation of 15 dB is used. In the daytime, the signal attenuation is set to 5 dB. An algorithm for controlling the attenuator in an intelligent mode with feedback by reading the ADC_overvoltage values was also developed. Attenuation is selected automatically several times per minute so that ADC overloads are as small as possible.
https://forum.kiwisdr.com/index.php?p=/discussion/2996/external-attenuator-for-kiwisdr-1
Repairing KiwiSDR receiver after thunderstorm.
Hello. KiwiSDR stopped working after the thunderstorm. The power supply goes into protection. There is a short circuit on the KiwiSDR power connector.
The BeagleBone board also stopped working. Separately from the KiwiSDR, the BeagleBone shows no signs of life and the TPS65217C chip is very hot.
The problem was not only in the failed transformer T301. The 5V power line had a resistance per mass of 5 ohms.
All linear stabilizers are out of order. Three pieces LP5907 and LMR10530Y. Moreover, the LMR10530Y was pierced through. That is, the 5V input was connected to the 1V output.
For further diagnostics, the stabilizers were replaced with similar ones.
KiwiSDR is working, but additional testing is required.
I made a short video of this repair.
Quiet switch mode power supply (SMPS) for KiwiSDR
