rz3dvp
- rz3dvp
- 1,144
- 6
wifi connection and local time
Interesting, you can start this curl from SSH manually, for your data it's looks like:
curl -s --ipv4 "https://api.timezonedb.com/v2.1/get-time-zone?key=HIHUSGTXYI55&format=json&by=position&lat=49.220001&lng=2.210000"
This request return something when KiwiSDR on the wifi connection or not?
73! Yuri -
New KiwiSDR is non-functional after upgrade from 1.2 to 1.383 [fixed, but root cause not understood]
Hi Jeff, you can test img from Dropbox? I downloaded it and see it's have more newer version than in KiwiSDR box - 1.46...
http://kiwisdr.com/quickstart/index.html#id-dload
And be patient first upgrade need lot of time ~45-60 min
Hope it's helpful... -
Displaying sunrise and sunset times at your Kiwi QTH in your Kiwi UI
