ZL1KFM
- ZL1KFM
- 30
- 2
My KiwiSDR has Died [power supply problem]
Good Morning John,
I have followed through the information you have requested.
- When the BBG is running by itself, the LEDs are pulsing, as they are processing data, and then 1x LED pulses as a heartbeat. The Ethernet LEDs are lit, and traffic is pulsing as one would expect to see. (had video, but not needed now)
- On the Kiwi board itself, detached, there is good continuity between the power pins and the 2x pins on P9 (5VE and Gnd). When the 2 boards are connected I have .725Mohm of resistance (725Kohm).
- OK, lets go back, I have now just tried a brought, brand new 5V, 2A power supply (#4) and the Kiwi is living. Of the 3 I had tried, two had 5V/2A on the plug, 1 only had 4V, so appears a power supply issue.
Thanks for your advice. Regards Kevin.
