Same for me: Chrome 90 still not solved the timing problem. I used it for DRM (IQ mode) decoding, and the constant distortion in signal timing is really annoying. zfyoung
As Zyg suggested, I did a quick IQ test over Firefox brouser, and it turns out working quite well. So it looks like a brouser problem after all. Not sure why IQ doesn't work with Chrome anymore ☹️ . zfyoung
OK, on further test, I can confirm the internal DRM extension continues to work. My bad! I'll try firefox next time, thanks for your suggestions. zfyoung
I use both internal DRM extension and IQ audio out. For internal DRM decoder, it doesn't show up any successfully decoded info. eg. station ID. For IQ output, I suspected the IQ audio signal is corrupted. It looks likely the timing of IQ streams is …
Hi, John. When 2 servers are on the same frequency, It only generates one single file. Is this your intention? I'm a little baffled by the inconsistent behavior.
My bad! I missed the "--f2" typo. This time around it seems works, Thanks. I'll let you know if something is not right.
Updated to the latest kjs-v0.1, and get this screen output. Also ONLY one file is generated, even I intentionally use 2 distinct frequencies. D:\My Documents\Downloads\kiwiclient-jks-v0.1>python kiw irecorder.py -s hallmann.selfhost.eu -p 80 -…
Please bear with my stupidity: I try to record 2 IQ streams from 2 kiwi Servers in this fashion: while True: recorder = KiwiRecorder(options) options.server_host = options.server_host2 # second server options.server_port…
Hi, John. I've had some problems with your patch (jks-v0.1): For some SDR devices, I get this run time error: "IndexError, tuple index out of range " at "kiwiclient.py", line 238. That line is "samples = [ complex(data[i+0],…
Glad that new release is out. When I mentioned " diversity reception", I actually have frequency AND/OR spatial AND/OR polarization diversity in mind and the targeting signal is DRM digital radio signal. Since kiwiSDR can coordinated signa…
Great! And thanks for the hard work.
Thank, jks. I've tried your updated script, and indeed the wave file sounds not quite right. Specifically, I found the recorded AM station signal losing its carrier peak in its spectrum plot. Wonder if the kiwi server ever respond with the correct &…
No, it just stuck before it could print out the "Block" and "RSSI" values and went on to generate wave file. I looked into the script and it turns out the callee "process_iq_samples" in "kiwiclient.py" defined…
Hi, I've looked into the python code. Unfortunately this code is not working for IQ recording (other modes are fine), and since I'm new with python, I would greatly appreciate any expert in that regard help to add a patch to that script? Regards …
Thanks for your fast response, jks. I'll take a look into the URL your provided and see if I can make it work.
In case this may help to explain the cause of occasional dropped-out in Dream: when dream dropped-out is internet related (packet loss, network congestion etc.), watch out for the momentous blackout in its waterfall spectrum plot. Otherwise this is …
