wa6our
- wa6our
- 25
- 1
An update. My MacBook Air running 26.01 works fine. Appears that they have made a change in 26.1 Safari that is causing this issue.
Much as I hate to, I guess I will use Chrome to access my Kiwi's. Hopefully Apple will unmake the change to Safari that is causing this issue. jks, thanks for your help! Jim
Yes. And now Kiwi-1 is exhibiting the same issue. It doesn't happen on my Mac running Ventura. However it happens on both my MACs running Tahoe.
Your suggestion fixed things for KiwiSDR 1. However it didn't work for KiwiSDR 2. I restarted the KiwiSDR software but it made no difference.
Well. I finally rebooted my KiwiSDR and now it is responding correctly. I first tried rebooting my router, but that made no difference. After rebooting my KiwiSDR it started acting normally and appears on the maps. Thanks for your help and ideas…
I checked my Comcast/Xfinity page and it shows "Your Gateway is in Bridge Mode". I use my own WiFi router instead of Comcast's. I also have my KiwiSDR connected by a wired connection rather then a WiFi connection. JIm wa6our
Another update. "kiwisdr.com registration status:kiwisdr.com/public registration: successful" Jim Gay wa6our
Forgot to add that it shows "sdr.hu registration status:SUCCESS (update)" Jim Gay wa6our
Ahhh. That could explain things. A possible power surge that took the Kiwis down but none of the other devices. I will work to find another supply. Thanks for the information.
I use Jameco 5 volt 1 amp power bricks that use a transformer. I have many other devices on the same power outlet and know of them go down. Here is what the messages file shows: Feb 17 11:55:01 kiwisdr kiwid: 23:45:14.816 .... UPDATE: version…
Today when I woke in the morning they were both down. There were no lights on. I had to disconnect and reconnect the power plug to restart them. in the latest case I restarted them when I found I couldn't reach them from my laptop. What is stran…
Placed the antenna in the front yard and it is now showing around 25 fixes per minute. What a difference 20 feet can make. Plans now are to put it on the roof of the house to get an even better view.
I have acquired a longer cable and plan on moving the GPS antenna higher up on my house. Hopefully it will get a 180 degree view of the sky.
Looks like I am not getting enough "GPS Fixes per Minute" to qualify. My GPS fixes per minute is low. I guess I need a way to extend my GPS antenna up higher so I get man more fixes per minute. Jim - wa6our
And now I am off the map again. I was running a test and it complained of that I wasn't getting GPS fixes. Yet I am constantly getting good GPS fixes. Not sure where to look. Jim - wa6our
Very interesting. All of a sudden I show up. 1/2 and hour ago I wasn't there. Very strange. Jim - wa6our
