ukoda
ukoda
22
  • Thanks for that, it is now working as expected. I had read most of the documentation I could find, but clearly miss some of it, so thank for the prompt reply and educating me,
  • I had a similar problem when I changed my PSU to a cleaner linear one. In my case the problem is the KiwiSDR design does not like the supply ramping up too slowly so I fixed it by added a second power switch to the DC output of the PSU to use after…
  • @Tremolat Thanks for that. I have been looking at common noise filtering. I have modified the antenna cabling and I am waiting on some Ferrite Toroids to finish that process. I suspect the core problem is I have too much gear here that can radiat…
  • Done that mod, all working good now. Same noise floor with 50R termination on so I guess that cheap PoE adaptor was not coupling any noise in directly. Thanks for the prompt suggestions.
  • Thanks for the suggestion. In the fault condition the blue light does not come on. I tried plugging in the DC jack after power on the PSU and the light came on, so slow ramp up does seem likely. I guess the easy fix is to add a front panel power s…
  • @jks Thanks, relative to other stuff I would agree this is not a priority. I am assuming from your reply there is no client/server documentation for me to browse. I will probably dig thru the source code and see what I can work out myself, in betwe…
