trevmar
- trevmar
- 11
- 5
OK, all fixed now. Just a little linux work was needed, and I don't hack that every day....
Making headway -- turns up that "up" is a script which has to be executed "./up" Upgrade is now proceding, let's hope it finished OK this time :)
The tail of my /var/log/messages shows "action 17" going wrong. What is that? Oct 1 13:33:15 kiwisdr kiwid: 00:00:35.813 01.. UPDATE: check scheduled (startup) Oct 1 13:33:15 kiwisdr kiwid: 00:00:35.848 01.. UPDATE: checking f…
I have the same problem this morning. Kiwi server dead. Can SSH into Beagle but I have forgotten root password. Never mind, I fixed that one :) I was able to issue the mst command, and it responded correctly, but from beagle su I cannot issue k or …
Thank you so much, jks. it was a silly error of mine. From the script output I assumed that the root filesystem was the wrong name and not the MMC unrecognized. Backup completed in 2:20 once I popped the card out, then in again :)
I have hit another problem with the software install (I think). When I insert a 32Gig FAT32 formatted SD card and try to do a backup the KiwiSDR is failing to look for the correct partitions to back up. At least that is my interpretation. I want t…
BashRC (etc) were created by the first make install I performed. That's why I rebooted before testing that build.. Birdies turned out to be RFI. Perhaps from a neighbor's solar system? Once I get them under control I will look at the ethernet. Am a…
---> Under Firefox all is working well <--- Palemoon was not displaying the spectra, but Firefox is OK. This is strange, as I have been accessing KiwiSDR on the web with Palemoon and not having any troubles. My problem, I will look into it. …
New compilation is now running http server after reboot. I just get a photo of the board, no waterfalls, but I can at least start to look through the /admin pages to figure out if something needs to be initialized. Thanks for your help!
I am make ing a new compilation now. Will reboot and test it. Should I try the SD card as received from SEEED, or download the latest distribution? ---------------------------------------------------------------------------------------------------…
Incidentally, my board serial number is 3003, which might indicate that SEEED's initialization might be failing because of a new batch (3000-on)
root@kiwisdr:~# cd Beagle_SDR_GPS/ root@kiwisdr:~/Beagle_SDR_GPS# ls -al total 5744 drwxr-xr-x 21 501 staff 4096 Oct 12 09:18 . drwx------ 5 root root 4096 Oct 12 09:48 .. -rw-r--r-- 1 root root 5 Oct 12 09:18 .comp_ctr drwxr-xr-x …
Thanks for the explanation. Here is my output from ls /root ------------------------------------------------ root@kiwisdr:~# cd root@kiwisdr:~# ls -al total 28 drwx------ 5 root root 4096 Oct 12 09:48 . drwxr-xr-x 21 root root 4096 Jan 1 2000 .…
Here is the output ------------------------------------------------- login as: root Debian GNU/Linux 8 BeagleBoard.org Debian Image 2016-05-13 Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian Last login: Thu Oct 12 09:32:20 2017 fro…
