teotwaki
- teotwaki
- 26
I know almost zero about HTML but also found this from the Google AI mode: Check the Website's Input Type: The input field you are tapping on is likely configured by the website developer to accept phone numbers (using HTML type="tel"), …
Over the last week I experimented with versions of clearing website data in Safari. Last hour or today or today & yesterday. No effect. I checked General-Language-Region and it was set correctly for the US. I tried switching the number format to…
Hello jks! My iPhone 16 pro is on 18.7.1 which is marked as up to date. Safari browser. It is possible to jump to ios 26. I also tried the Utah kiwi frequency entry with the same result. https://forum.kiwisdr.com/uploads/263/4E2LNNQBI75G.jpg
Sorry for the late response. I was out of the US for a little while. I'm glad you caught the bug where all of the kiwis defaulted to the Omni. I had forgotten to mention that. The distorted audio is gone. If I was the culprit I will know to check th…
Necromancing my old thread. KFS has been under new management and the web pages were reworked but have various small flaws. There is no longer any “contact us” link that I can find since Craig passed away The SE kiwi may have an issue. As far as I…
Thank you to all who helped to decipher and resolve the issues at KFS, especially the volunteer staff there! (I have donated in the past and will do so again.) It has been fascinating to see how the issues I identified have been discussed and befor…
IOS 15.4.1 You are correct that I can use "Done" but there is no decimal point with that entry GUI. So I have to enter 4095 and then have to press the plus signs and steer to the right number of hertz. Before this I always had the Qwerty …
Hi Rob, Same problems using the same IOS on my iPhone 10 plus a new problem When I try to type in a frequency it does not invoke a QWERTY keyboard. Instead it displays a mobile phone 10 digit keypad. I can enter numbers without a decimal point and t…
