ssanzone
- ssanzone
- 39
So far, almost 2 hrs without restarts...
Hello to all. I have included all the blacklist you posted here, but my KiwiSDR still keeps restarting every 10 minutes o so... is there a way to block as stated a large range of IPs in order to avoid looking for any single IP that offends an cause…
You are right. I was working on doing my KiwiSDR brown-out proof so I installed between it an the power supply a battery pack consisting 4 NiCd batteries 5000 mA to support it until the automatic generator starts after 10 seconds to supply mains to …
After many click here and there KiwiSDR was updated. (Image) Thanks.
Ok. I did it. This is the screenshoot (Image) Then went to the log tab. This is the screenshoot Yes, the KiwiSDR is accessible from the internet. I just emailed the public IP to the support@kiwisdr.com email.
I looked at the update tab an found this: (Image) I arived hom an cycled the power just in case it needed a hard restart and nothing happened to the installed version. Ho can I force the required update?
Today, running on ver 1.337 the error is still present. With a new text line, the previous is erased so it is not working properly. First thing I did was a KiwiSDR server restart with no changes after that. Then I did a Beagle reboot and no changes …
Thanks for the prompt answer to my request. Regards.
Thanks for the info. Regards.
