oe9ghv
- oe9ghv
- 38
- 1
i am not shure how old the kiwis are. The S/N was #3112 and #2141. But it is possible the capes where mounted on a different BBG. But it is possible that these are the oldest two BBG we own. All other kiwis boot without an issue with external clock.…
Finally i found the bug. the beagel was booting, but the ethernet port was not coming up when the GPSDO was connected. I found this: https://forum.kiwisdr.com/uploads/263/Z3CNMO0PJR2H.png 2. Sometimes the Seeed Studio BeagleBone® Green's network po…
Yes, If the GPSDO is connected but off it is booting. As soon the kiwi gets a clock signal, it is not booting. 50 ohm load on the kiwi on J5 i have to try.
hi, thanks for you answer, but on the rx site i have a 5V 25A linear power supply to power all kiwis. At the moment they are powered from a linear dual channel lab power supply. both channels are isolated. but there is no difference if i connect bo…
I also have interrest in connecting to a specific channel on the kiwi. We have 2 kiwis on RadioHill and are decoding wspr with wisprdaemon.sh. At the moment 4 channels (kiwi1) for public users, and 8 channels (kiwi2) wspr. If i could select a chann…
WOW!!! Wsprdaemon is working really well! Yesterday evening i changed the band config a bit. Now it looks like i am on place 2. GREAT! Rob, there are running 2 kiwis fed by the same antenna via a splitter. One kiwi is public access and spotting o…
Hello, Glenn, the call used by the wsprdeamon now is OE9GHV. The kiwi uses OE9PTI for decoding. I compared it a few times searching the database for the last 60 minutes. The wsprdaemon heard 50 to 100% more! I am vy happy with this solution! This …
Hello, i found the failiure in my installation. I needed to change the locale from de_AT to en_GB on my raspberry. So it is a point-comma bug. Works now perfectly. For comparison there is a secound kiwi with a splitter at the same antenna witch is…
Hello, thanks for the great work! So far i got it running with a kiwi configured to 8 slots. But, the spottet frequency/band on wsprnet.org is not correct. Frequency is shown as 0.001470 or 0.001424 on wsprnet. the call for spots is oe9ghv-1 at th…
