la2zoa
- la2zoa
- 17
- 3
I just noiced that Powernumpty has a setup for syslog server above. I have a Synology NAS im my lan, I will try to set that up tomorrow. Thanks Stu! Knut
Well, I thought i had fixed it... at least the intermittent voltage drops are gone. (I am not sure the would have been visible even on a Simpson, since the were very short) This morning it had powered off again, and after manually restarted by toggl…
Problem Solved! last night, I pulled out my multi-meter and oscilloscope to make measurements on the Kiwi. The Kiwi is mounted in an aluminium cabinet with no external access to the 5V Kiwi barrel connector, since the cabinet also contains a LM-350 …
New shutdown 29/30 - 11: After the previous shutdown, I disabled auto update, the config is now: In Update Tab: Automatic check update: No, Automatically install: No In Control Tab: Daily restart: No, After restart fw is still 1.424, so there have…
Thank you, Ron. I don't believe there is a problem with voltage drop in the power supply. The LM350T (3A) regulator is less then 6 cm from the Pi, and has an additional 220uF capacitor at it's output. There are no problems with initial start-up fro…
Great John! This is a valuable improvement I appreciate! Also thank you for the rapid response! (And I receivedr my second Kiwi today ;-) ) la2zoa
Thank you for a very quick response, John! Setting Google public DNS as default may work in many installations, but not all. An alternaitve would be to set both Google AND local Gateway in resolv.conf, since the the gateway router would normally be …
