                I don't know if this is the right place to post an issue/question, but today I hit a glitch while prepping a new BBAI for my KiwiSDR. After updating Debian (https://beagleboard.org/upgrade, minus the sections on TI deep learning tools, WiFi, USB and…
                BBAI sounds worthwhile. Is that just a straight swap, or is there more config involved? If the latter, anything good to read on that?
                Good tip there on enabling ssh without the use of a local console. I didn't realize I could ssh to a new OS that had just been installed from .iso file, but using the trick of placing a file called "ssh" on the SD card got it to work. The…
                Thanks, think I gleaned enough to try setting up wsprdaemon. Will give it a go as soon as I can put my hands on the microHDMI adapter for my RPi 4 (funny how there always seems to be one show-stopper bit/bob).
                Thanks! Is there a KiwiSDR-specific tutorial on setting up wsprdaemon?
                Ack - now that would be the problem. It'd been a bit since I set up the first KiwiSDR, and I'm just used to putting microSD cards into devices like this, so did it out of force of habit. Took the card out, restarted, it updated the software, and now…
                Thanks, I'll try using the 5V 3.5A PSU with the two KiwiSDR's for now, then work with the buck converters. It would be nice to consolidate all 12vdc and 5vdc devices to use a single power source.
                Thanks, I've seen those mentioned, and they're certainly inexpensive to try. Are certain bands known to be affected more by noise from the buck converters?
