iw2nke
- iw2nke
- 127
- 12
My first question is: why I see this message if the thunderstorm mode is disabled? https://forum.kiwisdr.com/uploads/433/EAFTD5YTU8HD.png
Here the workaround, so you will see all the paths impacted as far as I've found. location = /VER { include /config/nginx/proxy.conf; set $upstream_app 192.168.20.10; set $upstream_port 8073; set $upstream_proto http; proxy_set_header Upg…
John, many thanks for your analysis. Unfortunately, the call of kiwi_load2 through kiwi_ajax is addressed to the base url /VER and the path is generated by this code. It should be "https://poliham.deib.polimi.it/145m2ms1/VER" but the requ…
I apologize for this long post, it is the last of this kind but I think it will be useful to someone else. As promised, I've encapsulated the Kiwi in a 14TE cassette from nVent Schroff after some CNC mechanical work to have the right hole as recomme…
Here some preliminary results. The measurement conditions are Kiwi running at 1 GHz, with 14 channels used to carry the IQ stream to a wsprdaemon client. The ambient temperature is 20° C, without any relevant airflow (artificial or natural). The b…
Following the instructions the output of make install is: make[1]: Entering directory '/root/Beagle_SDR_GPS' disable window system systemctl stop lightdm.service Failed to stop lightdm.service: Unit lightdm.service not loaded. make[1]: *** [Makefil…
The PWM frequency for the fan control is usually 25 kHz, so I share with you your concern about RFI. It is also true that the current for this control is less than 1 mA at 3.3 V. Let's look at the results ;)
Just to keep you updated, if interested. Now I am able to read the RPM (revolutions per minute) of the fan connecting the tachometer output at the pin 8.35. The reader, not optimized, is consuming less than 1.3 % of the CPU. Next step is to control …
Usually to run a fan at the max speed reduce the life and the MTBF. Moreover in our case the goal is to stay below a reference temperature. In winter with low temperatures probably the required forced airflow is significantly lower. Last point is th…
I am working on a self controlled fan cooler for the BBAI+kiwi. It is possible to assign through pin mux two unused pins of the cape/headers on the BB AI to manage PWM and to read RPM output, as GPIO in? After the review of the package I suppose th…
