ic8pof
- ic8pof
- 298
- 1
                OK John abt the messages file. Jim ZKD makes a strong observation abt Debian waiting\or-not for the LAN connection. Let us see what the further development will bring in such small super box. 73 Phil
                HI tnx for the suggestions, I will try to ssh asap. My modem-router is an old Netgear DG834 and has the DHCP ON and I think it is stil working fine.... >ZKD: not sure about your suggestion. I use already a fixed IP for the KIWI, I have red somewh…
                HI John and Ron. >John: no I dont ask two things, I wanted just show how small place is shown on the KIWI waterfall compared to the "COMPACT" option of SDR_Radio window with the same pixel sizes and how much space is needed for the KI…
                ...... I waited to be out of 1st of april ehehe... HI here is the COPY\PASTE of my KIWI log when I switched the AUTO_NAT rule: ---------------- LOG crop from ic8pof ON--------------------Sun Apr 2 15:46:06 2017 0:00:05 .... upnpc : miniupn…
                on the Netgear DG834 modem the UPnP is ok with the auto assign of the 8073 port, but have no indication in the NETWORK admin page of the KIWI other than buttons YES and NO in green\grey. Maybe because I have not disabled the manual port in the rout…
                HI John, it worked already yesterday by removing the +5V, I tried also to unplug the LAN socket but did not wait 10 secs. Today the kiwi started again normally. The LAN unplugging is a very difficult operation to make when the kiwi will be in the re…
                HI All , as I am quite new in the Linux world, where can I read more about the GPIO switching board ? 73 Phil IC8POF
                oooHPS... JUST discovered the clik+left-mouse to add a label .....:-B have to put my glasses to read hidden functions... 73 Phil
                HI agn, tonight by resuming my pc from hibernation of yesterday when ---buttons did not work the minus tuning buttons are operative again. The OS is win7pro, FF full updated, in the problems page there are no issues . 73 Phil IC8POF
                HI I will try agn this afternoon and report more about... 73 Phil
                ... works also from KIWI (copy) and pasting into my logger input field.... Phil
                tnx
                SOLVED .... I was trying in the wrong direction : from the CAT software toward the KIWI. The working path is: get FREQ(copy) from the Logger program and paste into the KIWI input field. That is all. With ONLY 6 mouse clicks I have the KIWI sync_ed t…
                HI John , I understand all. Hence my idea of a "manual_CAT" copy&paste manually in the meantime a full_CAT program sees the light. The problem is that your field freq input takes xxyyy and the others are xx.yyy. If I paste xx.yyy ie 1…
                HI Ron, beside all the difficulties in the programming field my MANUAL_CAT idea should be a simple trick in awaiting for a full_CAT. COPY manually from 3rd party program and PASTE into FREQ_Field of KIWI. ...simple no?!... I have either MicroHam in…
                GE Martin thank you for the AGC pdf, it is always interesting to re-learn almost forgotten characteristics plus the digital part. In an ANALOG radio the AGC is that never-used switch, or by me just in few cases put on FAST , never on OFF and always …
                HI , I am just on v1.58 now as the update is in auto-mode. I think it is my fault as the Thresh level was too HIGH ....... was experimenting with the cursors yesterday and I have not jet realized what is their use..... now am listening again ;---((…
                HI Ron, your idea of one RX per ear was in my mind already from many years. Same feature as on my FT1000mkV_FIELD with its two radios. I have to add it to my audio switcher. For now I have a manual switch with which I listen from TRX_radio or from S…
                HI John. Yes some explaining points should be clearer HI HI. I am using a chinese made psu variable voltage and rated at 3Amp but sold by EU distributor REICHELT.DE Goobay EcoFriendly NTS3000EUP, it is mild warm and even if I measured 400Hz spikes o…
                ...all solved... I have forgotten to click also a blue-light BUTTON.... now it has changed the ip. sorry for bothering. 73 Phil IC8POF
