Success today,Thanks to JKS after a adjustment of the Ethernet interface MTU to 1344 (network tab). 4G connection now possible. v 1.819
Unfortunately, this is had not been able to be resolved. So Im back to square one. My next question is any one in the UK accessing via a 4G router. If so what type and which network. And secondly what settings if any were made in the router. Im look…
Thanks will do.
HI I am now unable to use the admin interface because as, after a few seconds it keeps looping around server has closed connection, a 60 second timer comes up, and the same thing happens. Note this is also occuring when on the main router as well a…
HI I have clicked the reverse proxy button and restarted, but still have the same issu e. https://forum.kiwisdr.com/uploads/695/QJDHJ0P1RDNV.png
OK I have managed to close the other browser, but still have the same issue. https://forum.kiwisdr.com/uploads/059/ZEQANXF65AT3.png
https://forum.kiwisdr.com/uploads/047/YG26GAYI1VRE.png I tried that earlier but now getting this happening have to keep power cycle the kiwi
I have done a reset. But will wait to see another user locally to see if they can help to solve the open port issue.
Hi. I have checked the correct key is entered. When using the url http://g8gpo.proxy.kiwisdr.com it brings up the kiwi. website. David
Hi. Sorry I am still having a issue I have entered the user key for the proxy service. When I check on the admin to see if the route port is open I get a Yes from the proxykiwi sdr . But a No from the other IP address. I am now wondering if I …
HI Yes, have filled out the webpage, public tabs, and set to yes. The reason for the 4G router is the location will not have any internet access. the noip DUC URL is http://herts.hopto:8073 I havent tried the kiwi proxy service as yet. David
