fotografm
fotografm
4
  • Problem solved !!! Thanks to the extremely helpful comments from jks via email. I switched the ethernet speed from 100Mb/s to 10Mb/s and the birdies went away instantly. I had tried 3 different routers connected to the ethernet port and the problem …
  • https://forum.kiwisdr.com/uploads/656/E7VFAUZD4ZUI.png The black band is where I unplugged the antenna for a few seconds.
  • I am using a Meanwell PSU which is recommended by kiwisdr as it is a lower noise switch mode psu. I also try it with a raspberry pi psu with the same result. I can't find a 5V battery here otherwise I would try that. It no longer seems possible to b…
  • I just got a KiwiSDR kit from OKDO in the UK. It has horrible birdies every 30kHz or so on the waterfall even with no antenna connected. These also radiate from the unit and I can see them on my X6100 with sniffer antenna. I tried several low noise …
