Aha! It worked! Thanks! I suppose that the server was in trouble...
Gosh, could it be that the upgrade fixed it?! I can see myself now Thank you very much for the help, man, and keep up with the good work, I love my Kiwi, it's an unique thing and an unique ecosystem Fabrizio F4VUK
Extensions -> TDoA -> TDoA server URL
https://forum.kiwisdr.com/index.php?p=/discussion/comment/17157#Comment_17157 Uhm, I changed the URL to empty in the TDoA server settings. Apparently it's using this to register as its own address?
Here it is: https://forum.kiwisdr.com/uploads/933/UEZEMXN41QVI.png
Thanks jks for the debugging info. This is my connect page, I can't see anything wrong with it, what do you think? https://forum.kiwisdr.com/uploads/153/3FUH3DDDPY12.png
Yes! Definitely very interested, Kiwi is a fantastic receiver with a fantastic software
Thanks! Going to learn something :-)
@jks ... in my original thought the button "auto scale" was totally fine. If the plan is to reassign the slider to being offsets to ceil/floor maybe you want to turn the "auto scale" into a toggle, to enable and disable this feat…
@n6gn, technically you're right, referring to the noise floor of the receiver. Good that we got the message right, I was meaning the noise got from the antenna @jks, the colour map of gqrx should be open, and also the one of websdr. In general, I h…
Oh, this is a pity yet I understand your point and I wish long life to this project. What you say also means that the github commits will not reflect anymore the true status of the "official" software, correct? Anyway I'm happy that the p…
Ah! Thank you! This is a very big improvement, the graininess goes away and the signals look much better to me. BTW what's the meaning of IIR/MMA/EMA ? f
Hi, thank you for taking my suggestion into account! Unfortunately it does not seem to work here. The slider "WF Delta" cannot be moved. Am I missing anything? I use Firefox. Thanks fbx
Hi, just for the records, I have just connected my Kiwi to the Wifi, with a cheap D-Link DWA-121. I can see the improvements in the noise spikes (was already good, now it's better), so for me it was worth the effort. Thank you very much to all tho…
I am not sure I understand your second paragraph. One could keep the binning as it is and correct the final values in order to have an output that is coherent across different zoom levels. At the end the differences between zoom levels should be con…
Hi, the binning makes a good point indeed, and IMO the idea is to have a consistent, zoom-independent visualization. I would choose to normalize to a value that gives a visual output that is similar to the one that other high-end SDRs would give. I …
