fabiodidonna
- fabiodidonna
- 447
in fact I'm often adding dx label...
I sent you an email Many thanks fabio
I have replaced the power supply with the recommended Mean Well GST18A05-P1J but the reboot problem continues, 4-5 every day. Jan 13 05:26:10 kiwisdr kiwid: 13:04:54.976 0... 0 11750.00 kHz am z9 "192.168.0.5" Modugno, Italy (ARRIVED)Jan …
I had ruled out a power problem because in the log I saw that the reboot was starting, which should not have been written in the log (I supposed). I will try with a better power supply. thanks
allora la questione è più complessa di quanto immaginavo...
ahahah... non credo che abbiano un problema con te, sti attacchi sicuramente sono fatti a tutti i kiwisdr pubblici che trovano
Also I have detected attacks from this ip and also from 104.154.194.205 and 104.198.41.0, they are all Google addresses. If it helps, I have updated my blacklist with: 39.96.0.0/12 47.240.0.0/14 110.87.0.0/16 117.30.0.0/16 118.143.0.0/16 138.19.0.0/…
It seems that the problems come from these IP groups assigned to Google. So in the blacklist just add these addresses only (without blocking all 34.xxx.xxx.xxx and 35.xxx.xxx.xxx addresses). Network Name: GOOGLE-CLOUD 34.64.0.0/10 34.128.0.0/…
Addeds at my blacklist: 35.193.93.106/32 35.226.75.68/32 34.133.26.245/32 34.138.234.38/32 35.227.153.91/32 35.238.253.231/32 35.196.148.15/32 35.192.66.49/32 34.105.56.69/32 34.105.116.190/32 34.74.44.165/32 35.188.11.56/32 34.83.161.2/32 34.123.10…
