Ha! Just a few minutes before i read your post i tried exactly that. I successfully set a new password via the console. Thanks anyway. I'm no friend of root-login, so i will not do that, but I copied a RSA-key file onto the beagle , so i don't need…
Thanks, jks . All voltages there! Just waiting for the led's to stop flashing, then i will return here. Martin Edit: Kiwi is alive and kicking! I can connect to the webserver, it receives, all good. Just now it is updating to a version 1.6xx . It …
Thanks for the replies. Yes , the kiwi board is damaged, i measure 5V, but there is no 3.3V, no 1.8V etc. . So, we need to replace the voltage regulator , i suspect? Martin Edit: I mated the Kiwi and the Beagle , fed 5V to the DC socket and now mea…
I should have said that I have no original SD-card with Debian8, just the Beagle and the Kiwi, nothing else. I managed to flash the Image to a new card and boot from it, pressing the button near the card slot. After a long while the Beagle responded…
Hi, new here. I maintain a used , zapped kiwi (accidently, 12V were applied to the DC-plug) from the local club. The Kiwi itself is not working, but as long as i wait for the tech-guy to repair it , i wanted to update from debian8 to 10. The beagle …
