davegte
- davegte
- 75
- 1
What the problem was: Kiwi sends out a packet to say a configured port of 8022, with a random source port (as you'd expect). I didn't realise that when I replied to that random source port I needed to force my source port to be 8022, not the more us…
Hi John, I have now managed to get this working, so many thanks for your kind assistance along with others - all much appreciated. Dave
Hi Ben, Thanks for the suggestion. I've looked at that, but it's just emulating a controller (in place of the KiWi) not emulating a switch. However, now you've reminded me I could check if it talks to my code and updates itself from my reply. Thanks…
Hi john, Thanks for the prompt reply. Your time is much appreciated. I appreciate it's not your code and you don't have a switch. And I'm beginning to suspect no-one else does either:-) The irony of that is that I do have this feature requested by s…
Well, another day later and progress. Many thanks to Mike N8OOU for guiding me in the right direction. It seems I should be replying using the random UDP port that KiWi generates, NOT (in my case) 8022 as in the previous Wireshark traces (and as set…
Hi John, Thanks for the reply. I only have one KiWi, and I'd like this to work on a standard KiWi config setting. (Also I'm not a Linux expert and while I can list the file you mention I don't know how to edit it :-) As I understand it the ICMP port…
Hi again, I can see my timeout in the NETCAT line in my (only) KiWi as 0.2 and don't really want to change it from what any user would see on theirs. 200ms should be plenty. The fact remains that whatever I send to KiWi, I get an ICMP port unreachab…
Hi John. A lot to work through there - many thanks for taking the time to help. I'll do some more work on it based on your info. Thanks again, Dave
Hi John. I see three packets from KiWi upon pressing an antenna button. I'm responding to each in under 1 ms according to Wireshark timestamp. The data payload may not be correct but in any case the ICMP Port Unreachable message stops anything furt…
Still struggling to get KiWi to see UDP packets from me without giving me ICMP port unavailable messages??
That's even better! - thanks for the excellent support.
Hi jks, Many thanks for looking into this so quickly - that fixed it! (I can only assume no-one has tried using the switch since the facility was integrated) Not sure if I'll have to re-do this per bootup, but hopefully the next s/w update will be f…
Hi. I am trying to test out the built-in antenna switch with kmtronic-udp selected, as the only (afaik) UDP control option. KMTronic provide test code and I can see Wireshark packets received on my test PC where the switch will be when using the tes…
A big thank you for adding SSB Squelch. I feel that at a single stroke the value of the Kiwi network has increased dramatically. Being able to park a squelched rx on a net channel while tuning around on another slice is a real asset. Thanks again.
