captcha
- captcha
- 5
- 2
Done! I had two scenarios that didn't work, see below. connect to http://<mysite>:8073 connect to http://<mysite>:8074 (now fixed) connect to https://<mysite>:8073 (now fixed) connect to https://<mysite>:8074 In the list of …
Turns out I hadn't set up ipv_forward and iptables correctly. This is why pinging from the KiwiSDR didn't reach any of the DNS servers. It now also makes the 'Check port open' test successful (even though it still wants to check against http urls). …
Thanks for the feedback on the Norway site. I'll see if I can get in touch with Oyvind. And yes, it could very well be that there is still something missing in my setup. I've just been very excited that I finally got it to work over https but I may …
On that page, the 'check port open' test fails for both url's but this is probably because the page shows that it's going to test for http urls. Respectively http://www.marcelpost.com:8074 and http://:8074. I expect these to fail because the client …
That is interesting. Thank you very much for testing this. Last time I tried this was well over a year ago, so maybe newer firmware can now properly deal with this. I will try again and see what happens with the one I'm running here.
