As an addendum, I went on to set my Beaglebone up with a static IP address, which allowed me to define third-party (non Virgin Media) Domain Name Servers, which in turn gets around the problems with VM 'safety' settings, and gives me more privacy as…
Success, thank you very much. Timely, quality support is everything! Looking forward very much to joining the community.
OK, can't easily change my VM web 'safety' nonsense, so have edited the hosts file on the Kiwi, and a re-ping gave me the expected (correct) IP results. Power cycled the Kiwi, and currently monitoring the logs via PuTTY, and it's looking promising. …
I'm in the UK. I've updated my DNS settings multiple times over the years, so they could be from anywhere. I've always avoided using my ISP's DNS servers (I've been with many ISP's too) but now let my VPN provider use their own DNS's for my workstat…
I guess it's my VPN's static DNS IP's as opposed to my ISP's default DNS addresses...
When I do the same from my windows workstation I get this: I don't understand why... https://forum.kiwisdr.com/uploads/181/5PCYK31CPXDN.jpg
I get a positive response when pinging github from the Kiwi, but it doesn't resolve the IP to the correct github IP? Looks like a proxy from my ISP? https://forum.kiwisdr.com/uploads/429/KL86AHMK2L5G.jpg
Yes, I can get to that github address from my Win7 machine, and download the .zip Command line output attached for nslookup. I originally had a VPN on my workstation (now turned off) but it was only on my local machine, not my router so the WAN IP a…
I'm occasionally seeing "server will reboot after build" message in admin panel, so I tried adding an admin password, as found in this thread: https://forum.kiwisdr.com/index.php?p=/discussion/2346/will-not-update-fixed but no change. I ha…
OK, did a manual "check for software update", then clicked "build now" button, but there is no "console" tab? It's just rebooted to v1.2 again.
Latest loop contained a new 'action 17 suspended' messages: Jun 9 09:51:35 kiwisdr kiwid: 0:00:00 .... KiwiSDR v1.2 -------------------------------------------------------------------- Jun 9 09:51:35 kiwisdr kiwid: 0:00:00 .... compiled: Jun…
Nothing obvious here, other than a loop? After the "switching to new version 1.538" in appears to reboot to v1.2 Last login: Thu Jun 9 08:30:15 2022 from 192.168.0.10 root@kiwisdr:~# tail -f /var/log/messages Jun 9 09:23:00 kiwisdr kiwid: …
Just realised that I can get into the admin interface, and on the 'Update' tab, I see "Installed version: v1.2, built Jun 9 2022 08:47:44 Update to version v1.538 in progress" then "Automatically check for software updates - Yes"…
OK, power cycled. It's just gone back into the same loop...
No, no SD card inserted :)
It might be a Beaglebone Black actually. Don't know how to tell the difference. On login via PuTTY, I get: BeagleBoard.org Debian Image 2016-05-13 Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
