WB4klj
- WB4klj
- 494
- 2
I'm also having problems with the "spec" noise filter not always working after update. Bob
Here's what I have in my Status field under webpage on the admin interface. I got it from a post on the forum a couple years ago. Of course, change the Lat and Lon to your own location. <iframe scrolling="no" frameborder="…
OK, finally found the problem for me anyway. It's the (No Snap- Snap to nearest) option that was added to the menu when you right click on waterfall. I guess the snap to nearest option got enabled on some of my computers by default after a software …
I'm having same problem too. Started a few weeks ago. One laptop Win 10, Edge browser works. Another Win11, Edge browser doesn't work. Thanks, Bob
Hi John, Thanks for working on this. I may have been premature to blame this on a firmware update. I wanted to play with the new C-QUAM decoder and plugged in some headphones so I could experience the stereo separation. That's when I noticed the pop…
Just an update. I also experience this on online Kiwis with v1.438. Since I upgraded from v1.436 straight to v1.440, I didn't notice it til then. Thanks Bob
Hello, After upgrading to v1.440, I am experiencing mild audio popping and short glitches. Happens only on SAM,SAL,SAU,SAS and C-QUAM modes. Using Win 10, Edge and Brave browsers. Tried on other online Kiwis and same thing. No audio underrun indica…
I've noticed my kiwi disappears after 7 days and I have to reboot it and everything is fine again, until another 7 days passes. Bob
I get the same since 1.240 upgrade. Every 10-20 minutes short popping sounds like a loose antenna connection at the coax outside, except it isn't because the waterfall looks normal. Audio comes back with a delayed climb to normal level as if AGC is …
It seems once I close the extension, it will not reload again. I have to close that browser session and restart another browser session to get it to work. 73, Bob
