WA2TP
- WA2TP
- 374
- 20
This is good news. Not sure if it was an oversight, but will there be a selctable AM BCB filter? This was always a problem on version 1. Is there possibly the abiltiy to still view the full water fall/ spectrum when used in 14RX mode if not using t…
Thank you that is very helpful.
Thank you. That option was set to yes. Are changes that are made to the blacklist routine (scheduled)?
You are correct It was defineitely a reboot. However it was all 7 of them within 30 minutes of each other. Plenty of room on all stroage devices. https://forum.kiwisdr.com/uploads/693/X94F09W7YCEZ.png And 1 of them was rebooted 2x 15 min. apar…
Hi John, I am using Glenns GPS distribution board with a 40db puck antenna. Generally I get between 8-10 good at all times with mostly full sky view. I have been using this setup for just over two years now and its the first time I have seen this a…
Update: ML&S UK supply. I received my second Kiwi yesterday as expected from ML&S, no issues. set it up late yesterday and it is now up and running. 1st kiwi with BBAI running in 14ch mode, 2ND Kiwi running in 8 ch mode, both now merged w…
This will be the second one I have purchased from them. Shipping has been immediate (overnight next day air was standard). Price has been reasonable as it included overnight shipping (315). First unit is working flawlessly with WD and BBAI. I may br…
I ordered second Kiwi from ML&S Tuesday (UK), it shipped today. Will be here by tomorrow according to tracking. Looking forward to adding another 8rx channels to the mix totaling 22. I can then eliminate the 3 channels that were not able to be m…
(Image) temp is staying steady at 44-45c with 13 RX. single 25mm fan bolted to cpu, exhaust up, and a small 1" centrifugal blower transverse the heat sink.
Disregard,, all up and running.. would help if I completed the update the under Root...
I am finally getting to setting up the AI and I am getting the following errors.
I'm curious to hear if anyone has tried the fan cape for cooling? https://www.newark.com/element14/6100310/beaglebone-ai-fan-cape/dp/50AH3704?MER=AT-MER-ALL-BT-HIST-ALL-0
