No, it is a 28 port D-Link Ethernet switch (DGS-1210-28P). This is connected to my router with an Ethernet cable. There is a way to change the Ethernet speed on the Network tab on the Admin Interface. Most Ethernet switches should adjust to eithe…
I am editing this because whilst changing the Ethernet speed from 100 Mb to 10 Mb significantly reduces the spurs, it creates substantial wide band noise below about 15 mHz that makes the band below that frequency unusable. I found the spurs are si…
