W1EQX
W1EQX
57
  • I see. Thanks for the explanation. So where are the backslash and/or the pipe keys entered? I also just discovered the right-click mouse menu allows for changing the database as well. Now it's nightfall and the first KiwiSDR is fully utilized so I …
  • Martin, Thanks for checking. I've cleared my Chrome web cache and tried multiple computers with different browsers such as Edge to troubleshoot in the past. No change. It's just that one Kiwi.
  • Very interested in at least one (maybe two) KiwiSDR2 to add to the K1VL site. So count me in! Carmine K1VL
  • Wonderful! Are you looking for beta testers? I would be happy to volunteer my site and time. I have a very low noise set up and the needed antenna port capacity. http://sdr.k1vl.com:8073 Carmine K1VL
  • I second G8JNJ's suggestion on the option to select automatic updates for the IP blacklist. I would suggest the default be manual, as it is now, and to give the admin a button or a checkbox to enable auto updates. Carmine W1EQX
  • Great! That's perfect. I have it enabled and it seems to be running as expected. Thank you for including the function and thank for all your hard work! Carmine W1EQX
  • The synchronous AM mode is fantastic! I particularly like the SAS mode - it gives me spatial abilities on where interference resides so I can then select the proper lower or upper sideband of the AM transmission if needed. This mode is also a big hi…
