VK6KCH
- VK6KCH
- 56
- 9
The latest issue of Amateur Radio (Vol 93) has a great article on FreeDV on HF, by Peter VK3TPM. This has prompted me to do a bit of further digging around, and it really does seem like a great step forward, and so impressive that the codec is open…
Thanks for the two pieces of very useful help. So, it was of course, very easy in the end! Right clicking on the band bar (eg, on "NDB Utility") gave me the drop down menu, and I could then select the database that I wanted (which is then…
I'm not sure which version this change occurred in, but there seems to be a little bug whereby user defined DX labels aren't displaying above the waterfall. I've included a screenshot to show that the database entries are still in the unit. Is ther…
An update on my "shy" KiwiSDR : in short, it's back up and running! I didn't add any entries to the blacklist at all, nor make any config changes. I think it was just some strange race condition to do with powering up the entire remote si…
Just a random thought; what about using WSPR receive mode, and comparing the signals received at the local station, versus a couple of nearby stations? Wouldn't that achieve pretty tight frequency calibration? (The WSPR signals should be less pro…
Hi John and Thierry, Thanks for your replies. The KiwiSDR is behind a 4G router, so there's a stage of outbound NAT there (with no explicit port forwarding to handle inbound connections), and then on top of that, the 4G router is only assigned a C…
Is there a trick to making a remote site visible on the list of public sites? My remote receiver has generally been visible at http://22332.proxy.kiwisdr.com:8073/ but isn't showing since yesterday (it may have disappeared earlier, but I only notice…
Thanks! It works fine now.
As part of cleaning up the RF environment at my QTH, I ran a quick Apples-vs-Apples comparison on two switchmode power supplies. At least down at the VLF part of the spectrum, the newer Apple A1444 power supply (the compact little brick without the …
Hi jks, Dream's screenshots show that Doppler/Delay is displayed (eg, "0.36Hz / 3.49ms") and Interleaver Depth (eg "2s (Long Interleaving)") is displayed. I didn't see any screenshot that shows the number of subcarriers, nor the…
