VK2YCJ
- VK2YCJ
- 1,317
- 5
Hello Jim, CMI as in Common Mode Interference ? Okay, cables as in antenna, GPS, power supply and Ethernet ? Some Common Mode Choke designs created by K9YC using Fair-Rite Mix-31 cores might do a good job on those cables. I saw or read somewhere t…
That is excellent news. I am going to put one of my KiwiSDRs into a small portable box with batteries and use the spectrum and waterfall displays to show local HF band noise (0-30 MHz). I'm thinking that a trial and error exercise with common mode…
Hello John, do you know when the next Massdrop (now Drop) will be available ? The website suggests MAY-03 and suggests 774 requests. Thanks, Jamie VK2YCJ
Hello Rob, Thanks for the links and suggestions. Jamie VK2YCJ
John, I put in a Massdrop request and order a month or two ago and the money was refunded to me - I guess for the Seeed production delays that you mentioned previously. My Massdrop order request is still there with REQUESTED showing in red in a re…
Hello Rob, Thanks for that info. Its always good to find out info from those that have done it before. I currently have 4 x KiwiSDRs and Im waiting for MassDrop to mature so I can get another 2 x KiwiSDRs. Two of the KiwiSDRs have been in ser…
Hello John, Thanks for that tip and link. I have ordered a couple of the active GPS antennas suggested by Jim - PCTEL GPSL1-TMG-SPI-40NCB and Im about to order a couple of the splitters too. Thanks John, and thanks Jim. Jamie - VK2YCJ
Thanks Jim, That RPi project sounds very interesting. The links you gave above are very good and Im starting to order those parts. With regard to the active GPS antenna: 1. The specs look like the preamp has a 2.5 dB noise figure with 40 dB of…
Very good thanks. Jim, what does that Raspberry Pi in the photo do ? The Time Pi probably means it is a GPS synced time standard. Do you have details of that too ? Guessing aloud it possibly gives you the time standard over Ethernet for yiur l…
Hello Jim, Just got this message. Wow - you've included some great info so thanks for all of that. I'll check those links right away. One extra BONUS question - does the GPS signal contribute timing and/or frequency stability to the KiwiSDR ? …
Hello John and Jim, Okay cool. The KiwiSDR population is growing in your photos - same phenomenon here. I see from the links that your GPS splitter is available in different sub-models with options for amplifier and connectors and so on. Did you …
Hello John and Jim, Thanks for the answer and clarification. Jim, could you elaborate on the gear in your QRZ.COM photo ? Is the flat square box on the right a two way splitter for the GPS antenna ? And the small blue box to the left of that - i…
Hello John, As soon as you said that I realised I mis-stated the case. On all mono-band antennas a single instance of WSPR-autorun will operate and the remaining 3 sessions will be available for public users. So no special callsign feature needed…
The progress you guys are making with these WSPR mods is very exciting. To be able to have a multiband HF antenna and a dedicated WSPR KiwiSDR to decode 6-8 bands at the same time 24*365 is nothing short of amazing. Keep up the good work guys. 73…
Hello Martin, Great answer, I'll change to the 80m_JA version tomorrow and later when we have 8 x WSPR auto-run sessions running with the RPi mods I'll try doing both like you. That's a great suggestion. Thanks, Jamie - VK2YCJ
John, a TCI-530 is a commercial broadband HF antenna made by TCI in California. Pretty serious stuff. http://websdr1.utahsdr.org/info/TCI530.pdf
Hello Rob, Thanks for the reply. Ill order the Rpi and a spare tomorrow. I have 3 x KiwiSDRs that are going together in a box at a very low noise rural location with a shared antenna and front end protection. One will be the dedicated WSPR uni…
Hello Rob, I have a dedicated KiwiSDR running 6 x WSPR auto-run decoding tasks and I'd like to use your scheme to push that up to 8 sessions with better performance and greater reliability. The bands I would like to cover are 160m to 10m - 9 band…
Hello John and WA2ZKD, Yep, that is the problem - exactly as you explained. We tried running 5 and 6 WSPR auto-runs and it worked reliably. Running 6 WSPR auto-runs plus 1 x general coverage radio session broke it. So Rob's kiwiwspr scheme with …
Thanks WA2ZKD, I found the link to that info. http://forum.kiwisdr.com/discussion/comment/5179#Comment_5179
Hello John, yep that's what we figured. Up until now we have run 6 x WSPR sessions and left 2 x general coverage radio sessions available. In that configuration we had seen the waterfall display run very slowly and guessed that 6 x WSPR sessions r…
