You wrapped the entire id-kiwi-body element with an HTML center tag? My apologies for missing that. The result of an incomplete copy and paste at some point. Thanks for responding! Andy will now slink off in embarrassment :)
I tried both Chrome and Edge on two different Windows laptops as well as on a MacBook. I also tried Safari on the MacBook. I get the same result with all machines and browsers. I only noticed this after a user reported that for about the last month,…
I had them (bots) tying up the designated FT8 frequencies on just about every ham band. I masked them all but within days the bots were back on other frequencies.
Fixed in v1.511,512 April 20, 2022 Very much appreciated. Thank you! :)
I have blacklisted 70.32.23.77/30 and have also disallowed multiple connections from the same IP address. I don't know if it will work but I'm not going to send $US40 a year to someone just to find out what IP address they're using. I suspect blocki…
hams.live resolves to 70.32.23.77 so I’ve added that to my manual block list. I don’t know if that will work as I’m not sure that’s the address of their server.
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13474#Comment_13474 Thank you! Very much appreciated :) Not sure there's actually any need to display (no location). just blank would be fine, or even the IP address if something has to be di…
Please!!! at least give us the option to not display user locations! I'm watching a nearby user on the KiwiSDR. The panel shows him as being in Adelaide South Australia, several thousand kilometres away from where he actually. Just give admins the a…
I'm happy to do away with the IP based location function altogether. In my opinion no information is better than misleading or inaccurate information.
I use a relay which is keyed by the transmitter to disconnect and ground the KiwiSDR antenna input. I also use one of the ubiquitous "SDR protectors" which is a couple of capacitors and a couple of diodes.
Now on the fourth attempt. KiwiSDR had auto updated to 1.462 some time overnight. Followed instructions. Watched console window. Process appeared to hang at always2 after about an hour. Restarted server ... no change. Rebooted Kiwi ... no change. Wh…
