Tremolat
Happy new year 2025 !
Two KiwiSDR, AutreRadioAutreCulture, Trémolat, Nouvelle Aquitaine, France. Ask for a password to access it. Demandez un mot de passe pour y accéder.
- Tremolat
- 2,692
- 6
Hello everyone. It's a very good question whether or not to use an LNA. I use one primarily to compensate for the length of my antenna cable, which is 250 meters long. Secondly, I slightly increase the sensitivity of the KiwiSDR. The LNA needs to ha…
Technically, it's possible, though not easy to achieve. A transmitter would vary its frequency to represent the shapes of alphabetic characters. Regardless of the speed of the cascade, the letters would be more or less elongated vertically. What's c…
Hello, incredible! That's a very original idea. Best regards.
Hello, I'm listening to your receiver from Nouvelle-Aquitaine, France, Trémolat. The computer part, the stream, is very stable; that's already excellent. Now we need to improve the RF section and especially increase the gain on the shortwave band. F…
Dear all, this is why I have moved the receiving antennas as far away from buildings as possible. The antenna of my KiwiSDR #1 is 50 meters away. The antenna of KiwiSDR #2 is 250 meters away. The 75 ohm lines are buried about 40 cm. This is the only…
Hello FrankinAu, you have in the following document, pages #7, #8 and #9, my example of the casing of my two KiwiSDRs. This can give you some ideas. http://labroue.autreradioautreculture.com/Courdilles/KiwiSDR/Documents/Description_KiwiSDR_Tremolat.…
Hello, I think the attenuator is a great idea, and I use it all the time. My antenna has a high output level. I attenuate at least 5 dB. But sometimes the KiwiSDWr input saturates (Tremolat KiwiSDR #2). I attenuate then by 10 dB. On days with very l…
Dear smg, thank you very much, it's a pleasure. Currently, I am improving the ground plane of the antenna, by spreading cat litter. It is clay, a material that retains water, which is called Bentonite (grey calcium bentonite clay). To improve it fur…
Hello, I just tried it on my computer (MAC OS Ventura 13.7.1) and on Ipad IOS (18.2.1) and KiwiSDR version 1.800 (Trémolat, Nouvelle aquitaine, France), I get the following files (see photo). https://forum.kiwisdr.com/uploads/464/SF3B2RP12HDV.png Th…
Happy New Year to all, Very interesting topic. My KiwiSDR #2 is in a region of France where thunderstorms are frequent (Périgord, Dordogne valley, Nouvelle Aquitaine). And the antenna is vertical, 11 meters, isolated from the ground (radiating pylon…
Good evening, same for me, exactly the same. I followed the instructions, the Linux commands. Everything went well, without error. On the other hand, I manually deleted the Beagle_SDR_GPS directory to find free space. Now the two KiwiSDR receivers f…
Cher Jean-Luc, félicitations pour le SAQ QSL. 73´s
Dear Martin, sorry, I didn't have time to answer you earlier. Your method of observing parasites is great. I should do the same investigation (in the workshop, I have a Rohde & Schwarz analyzer that could be used for this. Now, I can't see mysel…
https://forum.kiwisdr.com/uploads/261/LMWGQGKX24UZ.jpeg https://forum.kiwisdr.com/uploads/224/4NLG1N7WRNX7.jpeg Dear all, I also receive such very strange signals on the two Kiwisdr of Trémolat (France, Nouvelle Aquitaine). The following images were…
Here, version 1.691 works very well on my two KiwiSDRs, version 1 (private) and 2 (public). For what ? I have a fixed IP address, a track. Europe, especially Spain and France, seem particularly affected by the disappearance of the Kiwi. The Portugal…
Hello, this morning on the map, many KiwiSDRs are purple or gray in color (especially in the United Kingdom). Many receivers in France have disappeared from the map too. If it helps you, I did update 1.691 last night (around 1:00 GMT) and I put my r…
Thank you very much, John
We have to look far for this interpretation. but hey, that's your point of view. In my humble opinion, the management of a website unfortunately does not fall within the scope of article 2, alinéa 2 point c, because this article refers to the case o…
Yes exactly. Such an option might help. the administrator could see the identifiers in the administration page or on the local Kiwi, but not other users. "xxxxxx" or "******" would appear instead of characters, or the name would …
Dear John, Dear Martin, I agreed with you, until the day the problems arrived. The person who was the victim of the code theft filed a complaint and the ANFR (national frequency agency) was notified. That's all I can tell you about the facts. Of cou…
Hello, an excellent read, a good article on the subject of noise rejection: https://industrial.panasonic.com/ww/ss/technical/n4 Best regards, Philippe
Dear All, oops, I thought the topic was about a linear power supply. Sorry. I had read it wrong. Best regards, Philippe
Hello, it's too imprecise to pronounce. If the internal resistance of the 12 Volt generator is low, its voltage drop for 3A will be low. So, when there is a high intensity, it will heat up. the regulation device will have to dissipate 20 Watts, a b…
Hi, There is currently a very strong solar storm, maximal level 5, of exceptional intensity. The Northern Lights were visible last night in Europe on the 45th parallel. And numerous radio disturbances were caused by this magnetic storm. All night, H…
Good morning, when there is a long cable length, I would tend to choose a GPS antenna with 40 dB of gain, and especially a low loss cable. Here, the cable is 30 meters long, if I want the two GPS antennas to be exposed to a corner of the sky. The Ki…
No better here, it went down to 7 dB(all), 6 dB(HF) at 9:20 GMT. I currently have SNR 8dB (all), 8dB(HF) at 10:41 GMT. Never seen it, so strong. Something curious is happening to the sun. Regards, Philippe
at 9:33 GMT, in Trémolat in Aquitaine, France. It goes back https://forum.kiwisdr.com/uploads/506/DDL69BIM098H.jpg
It's even worse this morning. At 9:16 GMT, I had nothing, here in Trémolat in Aquitaine, France. It is believed that the antenna is disconnected. I checked, this is not the case. There are only VLF and LF that pass and an RF source transmitting on 1…
Thank you very much Martin for this report. Here too in the South-West of France, it was very bad. My two Kiwis have never had SNRs this low. Storms (rain, hail, lightning) return next week. This year, they are very early and particularly intense, w…
