Steve_NA5C
- Steve_NA5C
- 30
OK, Got it...Thanks John Steve, NA5C
Hi Martin, Thanks for the info, Where do you set the DBfs scaling? Mine is in DB scale for the above mentioned settings. Thanks Steve
Thank You, dl7awl I appreciate your help. 73 Steve
Thank You John, I will give it a try..
Currently running Version 2 Kiwi, Is there a simplified backup procedure that is recommended? Thanks Steve, NA5C
