ShaneBrook
Can You Have a Check Box To Activate a Floating Window That Stays On Top Of The Current Window That Shows The Tuned Frequency In Selectable Font Size and Type for Sight Impaired People?
Thanks.
- ShaneBrook
- 534
- 1
ZL2LD, What proxy service are you using? JKS, I got reverse proxy key and I can't see my KiwiSDR on KiwiSDR Map.... And no public connections... What can I do to fix this? I am using Starlink now... I did bypass Starlink router and using my own rout…
ip address error: "+x.x.x.x" Lots are in error.
Yes, Thank you, That worked!
I did the manual calibration and..... I was off..... now for CB Radios on USB and LSB it sounds right.... Thanks.... for helping me....
I realize that CB radios are not as accurate as the KiwiSDR receiver is. I've seen over the years that some CB radios are 'off' tuned. That's understandable, if they had a GPS receiver for frequency calibration and accuracy they would be dead on. I …
My Clock Freq is 66665900 The KiwiSDR has ben on for days after upgrade to Debian 11.9.
Thanks..... I will try that.....
I need to do sudo su, permission denied....
OK, Thanks a lot....
I did save in .bashrc, after reboot or update it disappeared. I listed all alias and it was gone. where did it go?
oh, sorry..... I made an alias command to do this: zcat /var/log/user.log.3.gz >> /tmp/kiwi.log; zcat /var/log/user.log.2.gz >> /tmp/kiwi.log; cat /var/log/user.log.1 >> /tmp/kiwi.log; cat /var/log/user.log >> /tmp/kiwi.log; …
root@kiwisdr:~# cd /var/log; du 0 btmp 0 btmp.1 4.0K alternatives.log 4.0K alternatives.log.1 4.0K alternatives.log.2.gz 4.0K alternatives.log.3.gz 4.0K auth.log.2.gz 4.0K auth.log.3.gz 4.0K auth.log.4.gz 4.0K debug 4.0K …
Look at this: CONSOLE: open connection df -h . root@kiwisdr:~/Beagle_SDR_GPS# df -h . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p1 3.6G 3.3G 35M 99% / root@kiwisdr:~/Beagle_SDR_GPS# df -h .; journalctl --vacuum-size=10M; df -…
I got it fived.... I found a link here.... can't find now..... I did this: M gil mc m mi Then everything OK..... !!!
How to fix?
https://forum.kiwisdr.com/index.php?p=/discussion/comment/19926#Comment_19926 How to fix ?
I get this: Installed version: v1.702, built Oct 23 2024 20:33:26 Filesystem is FULL! I tried this: CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# df -h . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p1 3.6G 3.4G 0 100…
I then rebooted and got this: Installed version: v1.702, built Oct 23 2024 20:33:26 Filesystem is FULL!
If I unplug the LAN Cable NO Freeze Up's... It just works Right, The way it should....
https://forum.kiwisdr.com/uploads/898/6J8AZ6NSD7C2.png I Tried this WIFI Dongle: BrosTrend Linux WiFi Adapter for Ubuntu, Mint, Debian, Lubuntu, Xubuntu, Mate, Zorin, PureOS, Raspberry Pi 2+, Windows 11, 1200Mbps, 5GHz/2.4GHz, Long Range 2X5dBi Ante…
It does this..... from reboot CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# lsusb Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS] Bus 001 Device 001: ID 1d6b:0002 Linux F…
When I rebooted I get this: connmanctl> services *AO Wired ethernet_7804738347d6_cable connmanctl> WIFI goes away.....
What is: <connection Id> WLAN ? config wifi_<connection Id> autoconnect on
Do I need to fix this? /bin/sh: 1: clang-6.0: not found (standard_in) 1: syntax error
I just rebooted and LSUSB don't show WIFI dongle.... and enable WIFI command don't work.... I have to reinstall again to get to work.....
I followed the instructions, to get it working. I have to TABs open, one to connect to the address of LAN and the second TAB connects to the address for the WIFI..... And then when I unplug the LAN you lose the connection on the WIFI and the kiwiSDR…
If I Disconnect the LAN from the KiwiSDR the WIFI and Lan crashes... What can I do to stop this? Thanks.....
I got it fixed.... Thank you....
I get this error.... root@kiwisdr:~/Beagle_SDR_GPS/RTL8811CU# make /bin/sh: 1: clang-6.0: not found (standard_in) 1: syntax error make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.19.94-ti-r42/build M=/root/Beagle_SDR_GPS/RTL8811CU modules make[1]: En…
Well, I got past the last error... Now, I'm stuck again.... connmanctl> enable wifi Error wifi: Method "SetProperty" with signature "sv" on interface "net.connman.Technology" doesn't exist
