SWL_VE5DO70
- SWL_VE5DO70
- 50
                Update to this issue: Recently the noise floor went a bit higher, although nothing equipment-wise had been changed. Problem traced to a LVPS feeding a set of LED lights on main floor in the kitchen. When shut off, noise issue cleared up entirely. …
                Hi John, when I look at the admin DX tab interface I don't see any date/time info. On the regular listening window, all frequencies with labels show up no matter what the schedule time. Re-loading the JSON from backup and restarting the kiwi server …
                So I've found that when the kiwi is rebooted or restarted the DX labels all load, but most of them do not have any day/time info attached. If I reload from my backup file (usually the JSON) then everything falls into place. Discovered this after a l…
                I discovered that if the kiwi server is restarted (or cold started) then it partially wipes out the time information on the labels. But it seems to keep the other data for each record, most but not all the start and end times get wiped. Not a proble…
                I haven't brought this up with them as I would like to go through all the things I might be able to do first, on my gear.
                Add to backgrtound: Using recommended power supply, this system was purchased from SEEED. As noted I have a ferrite on the PS lead going to the kiwi, just a few inches back from where the barrel connector goes to the BB.
                If I do get a data loss issue, I will take notes and forward to you. I can say though that there were no power supply issues as the utility here is quite stable.
                kiwi updated to 1.624, and file import works as described in the online wiki. All good ... many thanks John.
                Sent to you now PM.
