SQ8J
SQ8J
11
5
  • thank you for the hints, I managed to install it, the console installation via the webrowser did not work, I had to use putty and serial number as the password and it worked, everything works as it should, thank you again for help ... TNX !!!
  • |I use putty, but login to root and I don't now password.... is the serial on my kiwi's? I try to install by Console on the webrowser...can you do that?
  • I don't want to do a rebulid but an update ....
  • ok , thank you I understand everything, and please write me what commands I have to use to update the kiwi after logging in to the console tnx
  • but is it possible to connect to kiwi through putty from outside the local network ??? at the moment I do not have access to the local network where kiwi works .... upgrade via web browser does not work ... consola also: CONSOLE: only available to l…
