S57RW
S57RW
144
  • @jks Tnx a lot for implementing the option for controlling an external attenuator in v1.801 using curl commands. Have tested it today and works great. In the case of multiple clients connected if att setting changed by a certain client the update o…
  • Hi, Tested the Arduino-netshield with v1.695 and works fine. Instead of Arduino nano I'm using the Arduino nano 33 IoT with WiFi. Not tested with old nano if issues due slower MCU. My final version of the switch I think will be with STM32 and W5500 …
    in v1.695 Comment by S57RW July 2024
  • Hi, @jks I didn't notice earlier this thread and wrote about the same problem on another thread. I have same issues as SM0OHC described when using Arduino netshield. Tested with shell commands and all works fine so Arduino backend should be fine. H…
  • Hi Mike, I modified the Arduino sketch to work on Nano 33 IoT over WiFi. As mentioned above it works fine if in the admin console the antenna mixing IS NOT allowed. If I change to allow antenna mixing than when you select a certain antenna all the a…
  • Hi, Just noted and think what sm0ohc above wanted to say also after beagle reboot even if ant mixing was allowed it will be set to not allowed after reboot. Seems the setting isn't saved. 73 Andrej - S57RW
  • Hi, Have found the same problem. Decided to make my own antenna switch since have all material to build and the most practical/clean way to make with arduino netshield instead soldering all the wires to the BBB gpios and running it to the switch box…
  • Hi, PSU problem can be a probable cause of troubles since without Kiwi board all worked. I have a 5V 3A switching PSU which is running the Kiwi since years. Using it since it is quiet enough. But have never tested it what is the voltage drop or its …
  • Hi, Tnx for your above and your time. Have tried making the image by ssh to the BBB with same 8Gb card, script was executed without errors but didn't work. After reboot the image wasn't copied and Kiwi restarted working with what was on the onboard …
