Rene
- Rene
- 22
- 11
Hi John, thanks for this update!! I still have to find the "save as" option as an admin to make it default for each user so he/she don't have to fiddle around with the NB because I already did ;-). Maybe someone can make a help for this, …
I just found the new noise blankers. After fiddling around a few minutes with the sliders and both noise blankers, I managed to filter about 60% of the pulse out. It would be perfect to set a preset in the admin page (like BW to a station frequency…
Thanks for the explanation John. I'll NOT use the SNR poll because it is far from a good SNR test in comparison to the ears. Example, your SDR has a SNR of 28/27 dB (daytime). According to the SNR list, you own a good SDR and your ears tell the same…
The SNR list I'm referring to is http://rx.linkfanel.net/snr.html . The KiwiSDR itself generates this SNR score (admin page "Log"), you can change settings in the "Control" tab in the KiwiSDR admin page. I disabled the measuremen…
I just installed the SDR at the remote location, everything works fine like always on this network!? What the exact cause was, I never know because after erasing the blacklist, both local network and Mifi 4G didn't work. Later the Mifi suddenly work…
I waited for around one hour to let the data show up in the lists before going to sleep, I think it took longer than expected. Normally it takes about 15-20 minutes? No problem. The "external (classic)" SNR is average and always the same,…
When Yes/No is okay then it is good. Why I don't find my SDR in the S/N and public listing, no idea but this is the least I'm worried about. I think it was my LOCAL blacklist John. After so many things above changed, I switched to the Mifi and found…
Hm, after all the things done above, I perform a hard (5 VDC) reset on the SDR and connected the Mifi with 4G dataplan (forrest location) and guess what, it worked!! However this strange outcome: "Does kiwisdr.com successfully connect to your …
Also strange: "Register on rx.kiwisdr.com? kiwisdr.com registration status: rx.kiwisdr.com registration: successful" although I don't see my SDR at http://kiwisdr.com/public/ and http://rx.linkfanel.net/snr.html (also not after an hour). W…
It's getting even worse, I can't even check for updates anymore. Installed version: v1.517, built May 3 2022 11:04:12 Error determining the latest version -- check log It seems odd that 3 completely different ISP's (Ziggo, KPN and 4G Mifi) should ha…
The KiwiSDR just restarted but no result, so also not from this other internet provider and IP-address. Why doesn't it send a valid public IP-address? Which setting if responsable for sending a valid address each time a reset is done? I'm retired an…
Thanks John for the quick reply! Unfortunately I don't know what to do next. A few years ago I had to apply for the Kiwi reverse proxy because my provider (the biggest one in the country) had put me on the black list because I used the default KiwiS…
It's a pity that I can't move the antenna further away, the fence is only 10 m away. I tested with my Philips D2999 world receiver but also 50 m from the fence you hear the clicking noise, the SDR/Loop combination filters the click to a sort of plop…
Hi all, finally it's working! I didn't do anything since yesterday, somehow it worked right away as I refreshed at the alternative location, also enough 4G signal. I'm not sure how the data consumption will work out so I have put a 90 min 24 hrs cap…
Not happy anymore :-(!! The Kiwi was connected in no time and now I realised why. I connected the laptop via WiFi to the MiFi and THEN I can access the SDR without problems (same network) and could (re)register with a different IP number. But now I'…
I'M SO HAPPY :-)!! Today the Huawei Mobile WiFi Pro2 MiFi (E5885Ls) arrived. Micro-SIM (data plan only) in, did some adjustments (admin password) and connected the UTP cable to the Kiwi. I made a laptop WiFi connection, no problem whatsoever, could …
First the MiFi, maybe it works.
Thanks for your effort Powernumpty, nothing worked! I spend hours at this thing. I just ordered a Huawei E5885 4G LTE MiFi for 32 users, enough I think ;-). When this also not works, I will send the MiFi back and sell the carbon mast, the KiwiSDR wi…
The WiFi extender is a NetGear WN3000RP and the old smartphone is a HTC One+. I will try to power things down and up again, see what happens. In the menu's of the range extenders I don't see anything about bridged modes.
No idea if the range extender is in bridge mode, I have to access and look. The laptop connects perfectly to the UTP port and Wifi, no problems to get the hotspot signal through to the laptop and have a good internet connection. As I said, when I co…
Hi John, BIG thanks for the new update :) !!! The log shows that the I & Q values are being reset to default 04:16 CET. My SDR http://gti.proxy.kiwisdr.com:8073/ is alive and kicking again. The only thing, we have to "nuke" all the sh…
I'm already happy that there may be a solution for the "hanging" 100% AM-Gain issue. A reset or adjustment possibility that is. Take your time, nobody is hurt :smile: .
Check the high I and Q scores. Please help 73, PE0RBE.
(Image) This is what I see now...
Yes, I pressed the IQ bal button (of course when IQ plugin is enabled), I disconnected the antenna and zoomed in (no idea why yoy have to do this, there is nothing to find without antenna attached) to be sure that no signal is present. It seems that…
Edit, it is as if the AM Gain Control is turned up 100% so the receiver is "dead". Where is the AM Gain Control or is there a work around to get it all the way down again? Off course I reset won't help.
