Hi JKS, thanks again for your quick response. The procedure you described above worked like a charm. I can connect and use my KIWI radio again. So problem solved! I am still curious what was going on. Did the parameter disappear or was it never ther…
https://forum.kiwisdr.com/uploads/827/G3DALGWFBP1T.txt Hi, In case it is of any help I also copied (made a screen copy from the PuTTY screen) the admin.json file. As far as I can see the parameter "rev_auto" is not there. I have no idea wh…
https://forum.kiwisdr.com/uploads/292/20UNUSRJDCCK.txt Hi JKS, thanks for your quick reply. I located the logfile and copied the last part of it. This is attached as "log.txt". The part of the log I copied is repeated every 30 seconds or s…
Some more info. I noted that the time decoder extention uses the wrong frequency for the Russian time station RBU. In the name it says 66.67kHz (actually it is 200/3=66.66666...) but the extention sets the frequency to 66.57 (so 0.1kHz low). You can…
In the first place, it was not my intention to be disrespectful. If my posting was percieved as such, then I am truly sorry. English is not my first language... I merely tried to illustrate that sticking to the "official way" (frequency …
@jks Thank you for looking into this. I will experiment some more (and also try public kiwi's) to check if I can reproduce the "3 channel mode" problem that I reported, or find that I made some mistake (like not properly tuning FlDigi). …
I would like to react to jks' comment: {"o":-1030}] will show the triangular carrier symbol on 350 kHz but center the cwn passband on 350 kHz - 1030 Hz = 348.97 kHz. This hack is so that in a crowded NDB band you can see which carrier is…
@jks When I used FLDigi on my pc to decode the FSK audio generated by the Kiwi, the FSK decoding was flawless. The Kiwi was in "classic" (4 receiver) mode, The decoding sample above was produced using a windows 7 setup. I used firefox to…
Hmmm..... I experimented some more. When I switched the Kiwi to the "classic" mode (4 receivers) the problems became less. - The FSK decoding worked better (but far from perfect). See screenshot 1. - the Cr/LF after the RYRYRY and before …
