Owdjim
- Owdjim
- 157
- 1
That looks better thanks! wsprdaemon has resumed wspring and kiwirecorder.py has resumed kiwirecording. Thanks for the quick fix. Cheers, Chris
... and kiwirecorder.py also never seems to do anything. Log on the kiwisdr shows: Thu Jun 19 00:47:46 00:04:02.028 ........ [00] PWD isLocal_if_ip: flg=0x18 fam=2 socktype=1 proto=6 addrlen=16 192.168.217.68/192.168.217.68 Thu Jun 19 00:47:46…
This update seems to have broken connections from my WSPRdaemon system. Still trying to figure out what's going on.... Cheers, Chris
OK - probably a false alarm. I used the standard Debian release image to write an SD card on the BBAI-64 itself, then rebooted & flashed using that and all burst into life. I'd originally written the SD card on Windows - guess something got corr…
Does the Debian 11.9 / v1.665 image for the BBAI-64 have a static or DHCP network config? I'm having a play around with a '64 but it never seems to get a DHCP address with that image. If I use one of the default images from beagleboard.org it gets a…
One or two for me. Cheers, Chris
What was the audio content? Music? I suspect it may be a "playing now" music playlist. The recent tests from SE-TA appeared to have similar non-decodable content. It looks to me as if some DRM content servers have introduced a "versio…
Was 100W in the past.
And at 06:05 UTC even some signs of it again here in NZ, battling it's way through CRI! http://forum.kiwisdr.com/uploads/868/46YIITLO2TZP.gif Disclaimer - this is on my old FRG-100 not my Kiwi's 😀 73 Chris
Back in their days as bitXpres on 15896 kHz I actually heard them here in New Zealand, though only a few seconds of decoding. Still one of my best DRM catches ever though. 15785 is a much worse frequency with CRI on it :-( http://www.owdjim.gen.nz/c…
Rádio Nacional da Amazônia testing. 73 Chris
Hi John - the syntax of my cjson may not be 100% correct at the moment. I just based it on what I saw in the stations.cjson files on my own Kiwis. Our "regions" are different to yours at the moment too. Not sure if that will be a problem. …
CNR seem all over the place at the moment. Noted them on 13780 kHz at 1000 UTC from here in NZ. Not sure what, if anything, that replaces. Is there any way to get a Dream-style log file out of the Kiwi? I know I can record the IQ data and play it ba…
I had the same issue, but the manual upgrade process mentioned worked for me. Cheers, Chris.
Having had my KiwiSDR for all of 5 hours I'm already wanting to tinker :-) I'd like to be able to import the .csv files from the swskeds Yahoo Group. These import directly into the Elad SDR software I've been using and I'd like to do the same th…
